eliasafr
elevator torque tube
eliasafr
the screw of elevator tube found loose, it can't be tighten.....now is there any restriction of flying the aircraft in this condition,   and how the problem can be solve.....?
Ramrod
You have to refer to the 1C-130A-3 for guidance. If you find nothing there, you must request technical assistance from Lockheed. It is known that those screws strip out and the elevator torque tube collar bolt holes get elongated. The only repair for the torque tube collar issue is replacement. I do not think using oversized bolts were authorized, but I am not 100% sure on this.
  • Like 1
eliasafr
thanks a lot. yes just the same happened...I will be very pleased to get further information about this.....
miamiair
I've always used an engineering order for this as the -3 doesn't have a specific repair.
Old A/R Guy
I've had this happen a few times in the past (USAF Ret.) and the only repair is to replace the torque tube.
MR RELIABLE
YOU MUST CHECK COLLAR BOLTS HOLES FOR ELONGATION BY REMOVING THE ELEVATOR AND NUTS OF BOLTS INSIDE THE TUBE IF HOLES ARE NOT ELONGATED REPLACE NUTS AND ITS A GOOD TO GO OTHERWISE USE HIGHER SIZE HIGH LOCKS INSTEAD OF SCREWS 5/16 INCH I THINK  THIS CHECK IS ALSO PART OF MINOR ISOCHRONIC INSPECTIONS
Create an account
Register a new account
Sign in
Sign In Now
Champion Aerospace
