AMPTestFE
Nav panel lighting
AMPTestFE
Can anyone tell me why our USAF H1's are wired so that you can only see the SCNS mode advisory lights if you turn the nav instrument lighting rheostat up?  It turns out that these lights are wired into the dimmer rheostat.  So if you were flying during daylight, and you wanted to see the SCNS status lights, you'd have to turn the instrument lights on.  This seems wrong to me, especially since the pilot/copilot advisory lights are not wired this way.
tinyclark
It may be wrong, and I have no idea who made the decision. They had to be on some sort of dimmer for night ops. All aircraft are that way except for 92-0547 and up.
AMPTestFE
Thanks Tiny...was wondering if anyone would know a real answer.
tinyclark
It was an engineering decision by WR-ALC, and the guy that made it is probably retired. We had problems with the SCNS dimmer on the H's. It had a 5 Amp C/B installed and it kept popping. We did some checks and found out it had near a 7 Amp draw on it when all the way up. An engineer added the ECM panels to the circuit. The C-130 has to be the most undercontrolled aircraft in the USAF. I have tons of stories of one mod team coming to the base and saying they were going to put equipment or C/Bs in certain locations, then me having to tell them another mod already had those locales.
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Content
    • Mazurb
      By Mazurb
      We have a 74 year C-130H1 with a #2 VHF radio that wil not turn off through SCNS. Turning off SCNS also does not shut off the radio. We have swapped IDCUs, RTs and mounts, and have checked the Power on/off signal wire for continutity and a short to ground. Everything checks out. Also, Bypassing Secure voice has no effect.
      Has anyone seen this before or have any out of the box ideas? We've got a head scratcher here.
Champion Aerospace
