brownnard
Eng Gen 1, 2 and 4 fail on C130J
brownnard
Engine Generators 1, 2 and 4 fail acaws keeps coming up when engines are upsped to normal ground idle. Fault is intermittent and has occured on multiple attempted flights and maintenance ground engine runs.
Anyone seen this before or have any input?
Cheers
hehe
I'm assuming you have exhausted the FI for the associated faults?
What are loads on TR's?
What part number generators are you using?  There are two different C-130J generators.
Have you recently completed any heavy maintenance or are these pilot reported from a flight?
Foreign J?  USAF?
BBaldwin09
Not an Avionics tech, but I have seen something similar. From memory #3 Gen powers the Main AC Bus, but when #2 tried to power the Ess AC Bus there was an issue that would cause the three Gens to individually fall as each tried to power the Ess Bus. So the thinking was a loose connection or faulty earth. Now to throw a spanner in the works, in this case it ended up being an issue with one of the Props (Can't remember which one) De-Ice Timer Units being dodgy that created a similar effect.
Good luck.
UPDATE: Spoke to the AvTECH on the job, the issue ended up being Deicing Eng 3 short.
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Content
    • MatteoFTBny
      By MatteoFTBny
      hello dear all, i'm looking for 1 pc, p/n 370512-1R. this is a LEADING EDGE. aircraft is C130J, italian air force. anybody knows who is the mfr for this part? i do not want to through LM. it will be super expensive and too long lead time. thank you
    • munirabbasi
      By munirabbasi
      Hello C-130  expertise
      AC engine generator (leland) exciter (rotor) burn out (defect trend ),reason could not find out. expert opinion is required.
      Munir abbasi
      home  of hercules pakistan
    • herkman
      By herkman
      A C130J was lost at Jalalabad airfield and all six service and five civilian were lost.
      The aircraft from 774 expeditionary squadron serial is at moment unknown.
      We ask our dear Lord to keep these souls safely in his arms and bring comfort to their loved ones.
      Regards Col
      For consolidation purposes, all posts in this thread were moved to the here.
      --Casey
Champion Aerospace
