Dunbar
TD temp controlling chk fails in flight only.
Dunbar
I'm looking for a path to follow. Eng writes up TD system inop for a failed temp controlling check. I can get it to correct every time during mx runs and all other TD checks are solid. Has a new amp and Y-boxes good.
pjvr99
How is the in flight check being Performed? What steps? What is or is not happening?
NATOPS1
Agree with 99... What is the crew calling a "Inflight TD check"?
victorp1
If it is an outboard engine and the temperature controlling check is completed according published procedures and it only happens when wings are flexed (loaded) during flight you may need to look at the electrical connection at the wing break.
Create an account
Register a new account
Sign in
Sign In Now
Champion Aerospace
