C-130Hercules
Engine RPM after startup
C-130Hercules
Hi everyone,
After seeing this video, I have some questions.
I know that the turboprops of the Herc are constant speed ones, meaning the pitch of the blades is adjusted in order to gain speed.
In the video above, a Fat Albert is going through startup procedures. At 0:05 engine No.3 starts up and at 0:43 it seems like the engine is at idle speed. Then at 0:46 the engine increases its RPM which can be heard and seen.
This startup procedure is repeated for the engines No.4, No.2 and No.1.
When the video reaches 2:11, the engines somehow decrease their RPM. And with this RPM, the Fat Albert starts to taxi.
Is there some kind of switch to increase and decrease the RPM of the engines?
And what is the use of this increase and decrease of RPM?
I hope to hear from someone soon.
Kind regards,
C-130Hercules
pjvr99
The engines have 2 speed settings, low speed ground idle and normal. Low
speed is used to start and stabilize the engine, and also to do minimum
torque calibration. Engines are generally held in low speed for taxi as it is
easier to control oil temperature, than in normal. The #3 engine is
sped up to normal to provide extra bleed for a quicker start on the other
engines, and to provide air for the air conditioning packs. The APU
provides +-40psi air pressure (unloaded) while an engine provides 80
to 100psi, although this is regulated to 70psi on some
models
Also use of low speed reduces fatigue on turbine assemblies
  • Thanks 1
tinyclark
Sorry, I didn't see anything but the airplane dress.
C-130Hercules
Thanks for the explanation!
Sounds a bit like a helicopter. Helicopters have ground and flight idle, rotor speed is effected by these settings.
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Content
    • munirabbasi
      By munirabbasi
      hello expertise
      Engine oil suddenly loss during flight defect could repeat on ground operation
      munir abbasi
    • saikojer
      By saikojer
      Hye there, we are in progress to settle down on the defect "No 4 eng RPM overspeed 105%-106% and maintain in normal and mech gov"
      - During EGR found No.4 TORQUE, TIT and FUEL FLOW, LOW at crossover with RPM overshoot to 104%.
      INDICATION AT CROSSOVER.
      Torque : 1400lbs
      TIT: 678℃
      Fuel Flow : 990
      RECTIFICATION BEING TAKEN :
      -RPM adjustment.
      -Blade angle adjustment.
      -Null orifice + wormshaft adjustment
      -ectm
      -valve housing replaced.
      -syncrophaser
      - Coordinator resistance cx
      - tachogene resistance cx
      - Dome Assembly-SATIS.
      Still persist after a week :
      -Propeller and Valve Housing replaced.
      - SATIS.
      Still persist on next day :.
      No.4 engine RPM overshoot to 103.3% RPM on power advance with pitch lock symptomps.
      + RPM fuel governed out of limit.
      - pitch lock regulator - still persist.
      - FCU replace - SATIS.
      New snag after a week :
      No 4 engine nil low pitch stop.
      - Rigging blade angle and low pitch stop adjustment.
      -Valve housing adjustment.
      - Replace dome assy.
      - Replaced low pitch stop packing.
      *Still Persist.
      No 4 eng RPM overspeed  with TORQUE, TIT and FUEL FLOW, LOW at crossover with RPM overshoot to 104%.
      - Replaced Back previous dome assy + low pitch stop packing.
      * SATIS but torque anticipation very slow during advance throttle.
      *Throttle already at FLIGHT IDLE, TQ remain : 1.40 lbs.
      -After about 10 sec TQ increase to 3.4lbs.
      *Advance throttle, RPM+FUEL FLOW + TIT increase with low TQ until RPM overshoot until 104.4%.
      - Retard throttle, RPM drop and TQ can SLOWLY can achieved 7.5lbs.
      -Replaced Coordinator.
      * Still persist.
      - Replace another Valve Housing.
      *Still persist.
      Anyone got idea on this synthom ?
    • MaartenD
      By MaartenD
      Hello my name is Maarten, I am a Belgian last year high school student: aircraft technology. For my graduation I have to write a paper about the eingines of the C-130 Hercules. I've found a lot of information about the Allison T56 but it's more difficult to find the wright information about the Rolls Royce AE2100 engine. I need to know the differences between those two engines so I can compare them with each other. Do you know websites I have to visit or can you tell me somthing about those engines, any kind of information is welcome. If someone can help me with it I will be most thankful.
      Grtz Maarten
Champion Aerospace
