Nate Anderson
Help me troubleshoot!
Nate Anderson
I have an ECHS problem. One of our strech J's has all of the RH pallet locks, and PLCUs, not communicating with the MFCD. Actually it's all RH side and the LH side ramp locks that cannot be controlled/not communicating. Our bird just came back from Depot for the LAIRCM mod and now the pallet locks are jacked up. I've been looking in the WD but can't find anything that's in common with one whole side or the other. Any input is welcome/needed as I'm not too "savy" on this particular system. Please and thank you
                                                 SIGNED
                                      Mr. Sickof Chasingmytail
tinyclark
Did you get this working. I would contact WRALC first. Find out what the TCTO directs as far as disconnecting systems. It sounds like something was disconnected to me.
  • Like 1
hehe
There are huge cannon plug disconnects for echs that kill entire sides.  look forward of booster reservoir and aft near the ring sections where aircraft is extended.  most likely one of those is loose
  • Thanks 1
Nate Anderson
We did thanks. The mod guys left a cannon plug half connected
Nate Anderson
Thanks for the help, you hit the nail on the head. Cannon plug was half connected near hydraulic reservoir. Thanks
hehe
No problem man, glad to see it was an easy fix
tinyclark
So much for Op Chking systems that were disturbed. I'd like to see if that is called out in the TCTO. If it call for disconnecting, surely the check was needed.
Glad it was an easy fix.
Create an account
Register a new account
Sign in
Sign In Now
Champion Aerospace
