munirabbasi
ENGINE DRIVEN GENERATOR
Hello Hercules expertise ,  5 Engine Generators  have damaged (stators mounting screws broken) causes could not find out most probably vibration
Munir Abbasi home Hercules
Five total? Same aircraft? Same engine? or just five across your fleet?
mounting bolts or bolts on generator?
 Same aircraft but different engines.GEN stator mounting screws were broken and cooling Shroud also broken due to RGBs were defective these occurrences of vibration could not observe by flight crews, only  GEN OUT light came on with V/F/L zero.
Munir Abbasi
Edited by munirabbasi
Are you performing vibration analysis, prop balancing, torquemeter runout, 135 day signature checks with Honeywell VXP equipment? vibration maybe the key.
Thanks T56 GUY
Munir Abbasi Home of hercules Pakistan
