munirabbasi 13 Posted September 11, 2018 Hello Expertise What is rpm of engine starter turbine (airsearch company)? Munir Abbasi Quote Share this post Link to post Share on other sites
Moeed hassan 0 Posted October 18, 2018 On what condition???i Means at what level or stage u wanted to know the RPM??? Quote Share this post Link to post Share on other sites
munirabbasi 13 Posted October 18, 2018 7 hours ago, Moeed hassan said: On what condition???i Means at what level or stage u wanted to know the RPM??? Engine Starter Turbine RPM? Munir Abbasi Quote Share this post Link to post Share on other sites
Moeed hassan 0 Posted October 19, 2018 Sir my question is which RPM u wanted to know.... I means RATED... NO LOAD CUT OUT or OUT PUT rpm??? Bcoz these all are different Quote Share this post Link to post Share on other sites
munirabbasi 13 Posted October 19, 2018 (edited) 11 hours ago, Moeed hassan said: Sir my question is which RPM u wanted to know.... I means RATED... NO LOAD CUT OUT or OUT PUT rpm??? Bcoz these all are different Dear muddasar What is the 100 % RPM of ENG Starter? Regards Munir Abbasi Edited October 19, 2018 by munirabbasi Quote Share this post Link to post Share on other sites
Ahmer 4 Posted October 21, 2018 I think output starter RPM is 8250 approx. Regard Quote Share this post Link to post Share on other sites
Moeed hassan 0 Posted October 21, 2018 Absolutely.... Quote Share this post Link to post Share on other sites
Ahmer 4 Posted October 21, 2018 The limit of starter is 8250 to 8750 RPM. Regards Quote Share this post Link to post Share on other sites
munirabbasi 13 Posted October 23, 2018 On 10/21/2018 at 9:32 PM, Ahmer said: The limit of starter is 8250 to 8750 RPM. Regards Dear as you that at what rpm engine starter become ratchet slip(disengaged)? Munir Abbasi Quote Share this post Link to post Share on other sites
munirabbasi 13 Posted October 23, 2018 On 10/21/2018 at 7:14 PM, Ahmer said: I think output starter RPM is 8250 approx. Regard Just assume that your engaging the starter in flight ,at what RPM Turbine of starter is revalved? Thanks Munir Abbasi Quote Share this post Link to post Share on other sites
Moeed hassan 0 Posted October 23, 2018 IN FLIGHT why you wanted to engage the starter....as for as in flight no need of starter dear.... Bcoz inflight BLAST OF AIR TURN THE ENG NOT STARTER... for the starter turbine RPM just multiply starter gear reduction ratio with the rpm of starter u will get the answer.... I hope it u got my point. REGARDS. Quote Share this post Link to post Share on other sites
Moeed hassan 0 Posted October 23, 2018 Can u plz tell me WHAT ARE THE RPM OF ATM GEN MOTOR??? more over can u plz explain IF ATM MOTOR EXCEEDS ITS RPM LIMIT WHAT WIL HAPPENED??? Quote Share this post Link to post Share on other sites
munirabbasi 13 Posted October 23, 2018 (edited) 20 minutes ago, Moeed hassan said: Can u plz tell me WHAT ARE THE RPM OF ATM GEN MOTOR??? more over can u plz explain IF ATM MOTOR EXCEEDS ITS RPM LIMIT WHAT WIL HAPPENED??? I never heard ATM GEN motor . Contact me thru e-mail Munir Abbasi Edited October 23, 2018 by munirabbasi Quote Share this post Link to post Share on other sites
Ahmer 4 Posted October 23, 2018 2 hours ago, munirabbasi said: Dear as you that at what rpm engine starter become ratchet slip(disengaged)? Munir Abbasi Dear at about 9600 RPM engine starter disengaged & engine had enough RPM to damged the starter shaft if bleed is open.so at about 8290 we closed the bleed by releasing start button and starter control valve closed.here is caution if it start valve light not extinguished in 15 sec after releasing start button shut down the engine. Quote Share this post Link to post Share on other sites
Moeed hassan 0 Posted October 23, 2018 1 minute ago, munirabbasi said: I never heard ATM GEN motor Munir Abbasi Oh.... I see... Dear r u working on hercules or some other... I can guess this thing is eleminated from this bird but i think peoples working on hercules knows it or may not... Any how... Thank you for this. Quote Share this post Link to post Share on other sites
Moeed hassan 0 Posted October 23, 2018 (edited) 5 minutes ago, Ahmer said: Dear at about 9600 RPM engine starter disengaged & engine had enough RPM to damged the starter shaft if bleed is open.so at about 8290 we closed the bleed by releasing start button and starter control valve closed.here is caution if it start valve light not extinguished in 15 sec after releasing start button shut down the engine. Dear ahmer thanx for this but can we engage starter in flight by pressing starter button.... ??? My answer is NO.... what u peoples say?? Edited October 23, 2018 by Moeed hassan Quote Share this post Link to post Share on other sites
Ahmer 4 Posted October 23, 2018 1 hour ago, Moeed hassan said: Dear ahmer thanx for this but can we engage starter in flight by pressing starter button.... ??? My answer is NO.... what u peoples say?? Yes u can use for air start the engine , if prop brake locked. Otherwise it's dangerous and damage the startor shaft. Quote Share this post Link to post Share on other sites
