munirabbasi
C-130/Hercules Steering Control Valve
Hello Hercules  Hydro expertises
Can some expertise tell me, have you experience ,failure of steering control valve on C-130 A/B/E/H.
Munir Abbasi
Home hercules Pakistan
What do you mean be failure?
I have changed steering control valves on all of the MDS/models you listed.
Normally they are changed for leaking out of limits, changed during shimmy troubleshooting, or changed because of normal wear.
I have never seen one explode or anything crazy.
Thanks Chris  hehe
Can you submit me any lockheed martin service new/T.O regarding Steering Control Valve. or explain how it work and neutral
Munir Abbasi
home of hercules Pakistan
The valve is set to a neutral position during overhaul by centering the spool between the outlet ports.  What that means is that the valve should not port fluid when in neutral position, this can be a hard position to achieve during overhaul.
Neutral position should not port fluid.  Neutral uses the internal spring loaded accumulator to take out shocks and movement of the wheels during takeoff and landing.
Are you having problems with the valve porting left or right and not holding the wheels in center position?
2 hours ago, hehe said:
This service news talks about it.  If in doubt and you dont know how to rig/overhaul the valve, Just replace it.
V12N4.pdf
Thanks.
Hercules operator countries guys continue promoting/enhancing/contributing skill level of work center mechanic for maintaining safe operation of C-130 hercules big birds
Best Regards
Munir Abbasi Home of hercules Pakistan
Hello hehe Hydraulic Expertise
Can you explain what is out put of steering control valve (high pressure ports) for two cylinder actuator?
Munir Abbasi
Munir Abbasi
Are you asking what pressure is ported?
There is no pressure reduction in steering control valve, pressure to the actuators depends on how far you turn the steering wheel.  Full turn is 3k psi to the extend/retract side of applicable actuators (left/right)
Thanks
Best Regards
Munir Abbasi Home of Hercules Pakistan
