NESA WINDOW HINGE INOPERATIVE
munirabbasi
Hello World Expertise
PL Hing window inoperative (Electric Heating) of L-100 Hercules bat bird. Can bird fly at its normal altitude.Please describe limitation of NESA swing window and Difference of Military version and civil version hing window
Munir Abbasi
Home of hercules Pakistan
Edited by munirabbasi
4 hours ago, hehe said:
Typically NESA windows can be flown when in-op but it limits the pilots because they must avoid icing conditions.  This would be a judgement call by YOUR aircrew members.  Every Air Force or operator is different.
Can we remove Electric connections of inoperative Swing Window?
Munir Abbasi
INOPERATIVE WINDSHIELD ANTI−ICING                                Operation  with inoperative windshield anti−icing is  permissible  provided.        1. The airplane is not flown in known icing.        2. The  maximum speed limit below 10,000 feet is 185 KIAS  due to possible bird strikes. Descent  from high altitude into warm moist  air  with  an inoperative  nesa windshield anti−icing system will cause  fogging and possible icing of the windshield.   To minimize this, increase cabin air temperature and open the  pilot’s  and  copilot’s windshield defogging valves. It  is recommended that a gradual descent be made to allow the windshield, which has been cold−soaked at altitude,  to warm with ambient cabin air.
Edited by Ahmer
Munir Abbasi
To get FAA certification, it was required that the civil version had to have 3 positive locking devices on each swing window, whereas the military version has just one locking device.  The NESA systems are identical.
9 hours ago, NATOPS1 said:
You do not need to remove the wire from the window in fact you should turn off the NESA because if one window is inoperative it can cause the remaining operative windows to over heat. This information should be in your operators manual in the normal procedures section.
Thanks
Munir Abbasi
Can we replace the swing window of civil version with military version
Munir abbasi
Munir abbasi
You might be able to if the locking mechanism on the military version window lines up with the commercial version locking device on the window frame.
