Shola
GTCP85-180L APU does not attain combustion
Hello guys. GTCP85-180L does not fire. It does not go beyond 20% rpm and there is no combustion. We have replaced FCU, oil pressure switch, oil sequencing switch, centrifugal switch, igniter plug, exciter yet no combustion. It just rolls but never achieves combustion. Any help please.
Thank you very much. We replaced the atomizer. We will replace the auxiliary start relay.
On 2/22/2019 at 4:56 AM, pjvr99 said:
Is the ignitor firing? are you getting fuel from exhaust?
Yes. We are having fuel from the exhaust. Pls anyone with any further inputs regarding this issue?
you didnt mention replacing aux start relay and fuel holding relay. try that. also
try replacing 110% overspeed solenoid on back of apu.
back to ignitor: can you hear it firing?
We replaced both the aux start relay and the fuel holding relay. We also replaced the centrifugal speed switch (110% overspeed switch). We heard the ignite firing. We even saw the spark before installing it back into the combustion chamber. During one of the attempts, the APU rpm rose to 32% and got stagnated. The combustion chamber was also hot indicating some combustion. However,  the APU couldn't self sustain its operations. We have replaced virtually every component from FCU to oil pump to atomizer. We are however not sure of the integrity of the ignite as we do not have a new one in store. We have placed order for new ignitors for further troubleshooting. Thank you all for your contribution. I think we all can learn one or two things from this experience after we might have succeeded. Meanwhile,  kindly keep your suggestions coming.
ok. sounds like you got the important bits. when you started
troubleshooting, did you set cracking 57 - 63psi? did you
remove the control air line from fuel cluster while setting
cracking pressure? Have you changed the acceleration/load
control thermostat?
Hello experts. We also have an APU that quits after running for about 8 minutes. Any idea what could be responsible for this discrepancy?
4 hours ago, Bogi252 said:
How much fuel is in the #2 tank?
It is more than the required 2000 pounds minimum.
what is part number for this APU?
Model of the APU is GTCP80-180L. Part Number of the APU is 381116-1-7. Thanks a lot.
Ok was just curious. Gonna go out on a limb here because we had something similar
last year. Try replacing flexible oil hoses to and from the oil tank, and make sure the
rigid lines and the tank are clean and free of contaminants
Thanks buddy. We will try this suggestion and let you know the outcome.
Correction please. Model is GTCP85-180L
Shola, have you purged the fuel like to the atomizer, just prior to starting?  Checked in-line fuel filter PN 7507197?
Gentlemen,  regarding the APU that quits after 8 to 20 minutes,  a new centrifugal switch was installed and the APU has been operating properly now.
  • Like 1
