jflimbach Posted September 19, 2012 Share Posted September 19, 2012 www.internationalairresponse.com IAR is currently accepting applications for the following positions at the following locations: ■C-130 Loadmaster - Mesa, AZ ■C-130 Captain - Mesa, AZ and Gulfport, MS ■C-130 First Officer - Mesa, AZ and Gulfport, MS ■C-130 Flight Engineer - Mesa, AZ and Gulfport, MS * IAR is currenly looking for a Captain with C-130J experience * Job requirements and descriptions are listed below: C-130 Loadmaster Location: ■Mesa, Arizona Minimum Requirements: ■U.S. military C-130 Loadmaster/Jumpmaster training and experience ■Possess or be eligible for a US passport with no travel restrictions Preferred (not required): ■U.S. military C-130 Loadmaster/Jumpmaster instructor qualification ■FAA A&P Certificate ■C-130 maintenance experience Job Description: Applicant should possess the ability to perform Loadmaster/Jumpmaster duties for aerial delivery, parachute jump operations, aerial refueling (tanker), and oil spill dispersant operations (on-the-job training provided), as well as trainig and qualifying additional personnel in basic loadmaster/jumpmaster principles. Applicant should possess the ability to maintian C-130 aircraft as general maintenance technician and part of the maintenance department when not performing loadmaster duties. Loadmaster duties will typically take 50% of applicant's time. Applicant should be able to work remotely as part of a small crew from a location away from IAR's headquarters when required. Applicant must be able to travel out of the local area and/or U.S. for up to 30 days or more (travel typically occurs no more than two times per year). Contact: email [email protected] C-130 or L-382 Captain Locations: ■Gulfport, Mississippi ■Mesa, Arizona Minimum Requirements: ■FAA ATP ■2nd Class FAA Medical ■Possess or be eligible for a US passport with no travel restrictions Preferred (not required): ■C-130J expeience ■2,500 C-130/L382 flight hours ■Significant heavy aircraft experience ■Aerial application experience ■Aerial delivery experience Job Description: Applicant should possess the ability to work remotely and manage a small crew from a location away from IAR's headquarters. Position requires performance of Captain duties in the low altitude environment as well as personnel and project management duties. Candidate must be able to travel out of the local area and/or U.S. for up to 30 days or more (travel typically occurs no more than once per year). Contact: email [email protected] C-130 or L-382 First Officer Locations: ■Gulfport, Mississippi ■Mesa, Arizona Minimum Requirements: ■FAA Commercial Rating ■2nd Class FAA Medical ■Possess or be eligible for a US passport with no travel restrictions Preferred (not required): ■500 flight hours heavy aircraft experience Job Description: Applicant should possess the ability to work remotely as part of a small crew from a location away from IAR's headquarters. Position requires performance of FO duties in the low altitude environment as well duties assisting Captain as needed. Candidate must be able to travel out of the local area and/or U.S. for up to 30 days or more (travel typically occurs no more than once per year). Contact: email [email protected] C-130 or L-382 Flight Engineer Location: ■Gulfport, Mississippi ■Mesa, Arizona Minimum Requirements: ■FAA Turbopropeller Certificate ■2nd Class FAA Medical ■FAA A&P certification ■Possess or be eligible for a US passport with no travel restrictions Preferred (not required): ■3,000 C-130/L382 flight hours ■Heavy aircraft maintenance experience Job Description: Applicant should possess the ability to work remotely as part of a small crew from a location away from IAR's headquarters. Position requires performance of FE duties in the low altitude environment as well as field level maintenance duties. Candidate must be able to travel out of the local area and/or U.S. for up to 30 days or more (travel typically occurs no more than once per year). Contact: email [email protected] Quote Link to comment Share on other sites More sharing options...
cercel Stefan Posted September 27, 2023 Share Posted September 27, 2023 Hi my name is CERCEL Stefan, I'm from Romania and I work at Romania Air force like a flight engineer, I want to join us if is possible? Quote Link to comment Share on other sites More sharing options...
