moe986 Posted May 22, 2016 Share Posted May 22, 2016 Requesting advice on this problem. The engine won't shutdown normally (negative fuel cut). Pulling the T-Handle managed to shut it down. We've replaced the geneva lock & speed sensitive control. What else should I try? Quote Link to comment Share on other sites More sharing options...
Lkuest Posted May 22, 2016 Share Posted May 22, 2016 Have you tried the switch that tells the Geneva lock to close? It can be tempermental. I've had the same problem before in ground stop. Hitting the quadrant did the trick in my case, which means switch, but it could outright fail as well. There's a lot of wiring and components in the system, so I'd recommend hunting the problem down using a wiring schematic if it isn't the switch. Quote Link to comment Share on other sites More sharing options...
pjvr99 Posted May 22, 2016 Share Posted May 22, 2016 Lkuest got the first thing i'd look at - cut-off switch on the condition lever in the pedestal. However, for me,the left-hand harness and QEC kit wiring has been a source of shut-down problems for many years. Quote Link to comment Share on other sites More sharing options...
AMPTestFE Posted May 30, 2016 Share Posted May 30, 2016 Yep, either a bad switch or out of rig. Quote Link to comment Share on other sites More sharing options...
munirabbasi Posted June 4, 2016 Share Posted June 4, 2016 Condition lever SW/Touch-down sws/wiring/ FSOV Munir Abbasi Quote Link to comment Share on other sites More sharing options...
