munirabbasi 20 Posted September 4, 2018 Share Posted September 4, 2018 Engine flameout RPM drop to 94% reason could not find out Munir Abbasi Quote Link to post Share on other sites
pjvr99 35 Posted September 4, 2018 Share Posted September 4, 2018 Can you give us some more information ...?? Quote Link to post Share on other sites
munirabbasi 20 Posted September 5, 2018 Author Share Posted September 5, 2018 20 hours ago, pjvr99 said: Can you give us some more information ...?? Defect shifted to No. 4 and No.1 ENG in normal Governing mode, the mechanical Governing mode operation is normal. Munir Abbasi Quote Link to post Share on other sites
pjvr99 35 Posted September 7, 2018 Share Posted September 7, 2018 is this in level flight, during a ground run, taxi, descent, take off? what are throttle sttings? Quote Link to post Share on other sites
munirabbasi 20 Posted September 7, 2018 Author Share Posted September 7, 2018 7 hours ago, pjvr99 said: is this in level flight, during a ground run, taxi, descent, take off? what are throttle sttings? Throttles are in takeoff range on the ground, aircraft lineup in the runway for departure regards munir abbasi Quote Link to post Share on other sites
pjvr99 35 Posted September 9, 2018 Share Posted September 9, 2018 Thank you. based on this and your previous mentioning the shift to another engine, it sounds like you have a rollback, a problem with the synchrophaser. Check out synchrophaser, sych rack, and also run synch box tester. sometimes the problem can be a false signal generated by a seemingly good valve housing. also check all 4 prop pulse generators. Quote Link to post Share on other sites
munirabbasi 20 Posted September 9, 2018 Author Share Posted September 9, 2018 5 hours ago, pjvr99 said: Thank you. based on this and your previous mentioning the shift to another engine, it sounds like you have a rollback, a problem with the synchrophaser. Check out synchrophaser, sych rack, and also run synch box tester. sometimes the problem can be a false signal generated by a seemingly good valve housing. also check all 4 prop pulse generators. Thanks Regards Munir Abbasi Quote Link to post Share on other sites
pjvr99 35 Posted September 20, 2018 Share Posted September 20, 2018 So did you get it fixed? Quote Link to post Share on other sites
munirabbasi 20 Posted September 24, 2018 Author Share Posted September 24, 2018 On 9/20/2018 at 9:55 AM, pjvr99 said: So did you get it fixed? It was problem of NTS bracket got sticky Regards Munir Abbasi Quote Link to post Share on other sites
pjvr99 35 Posted September 24, 2018 Share Posted September 24, 2018 Ok cool Quote Link to post Share on other sites
Moeed hassan 0 Posted October 16, 2018 Share Posted October 16, 2018 Pjvr99 do u know what actually happend in this case???? Look dear as mr. Muneer is saying problem shifted to No. 4 and No. 1 respectivly..... So NOW THE QUESTION IS IF NTS BRACKET WAS FAULTY THEN Y IT SHIFTED TO OTHER ENGINES??? No doubt NTS may also b the reason but only for one engine not for all. Quote Link to post Share on other sites
munirabbasi 20 Posted October 16, 2018 Author Share Posted October 16, 2018 49 minutes ago, Moeed hassan said: Pjvr99 do u know what actually happend in this case???? Look dear as mr. Muneer is saying problem shifted to No. 4 and No. 1 respectivly..... So NOW THE QUESTION IS IF NTS BRACKET WAS FAULTY THEN Y IT SHIFTED TO OTHER ENGINES??? No doubt NTS may also b the reason but only for one engine not for all. Dear moeed as you that what is synchrophaser stabilizing mode and throttle anticipation. Please consult T.O IC-130B-2-11. How NTS system works? Thanks Regards Munir Abbasi Home of hercules Pakistan Quote Link to post Share on other sites
Moeed hassan 0 Posted October 16, 2018 Share Posted October 16, 2018 Job guides are there for fault isolation..... Ok fine with the throttle anticepation but my question is how probkem shifted to other engines if the problem was with NTS BRACKET itself... Quote Link to post Share on other sites
munirabbasi 20 Posted October 17, 2018 Author Share Posted October 17, 2018 19 hours ago, Moeed hassan said: Job guides are there for fault isolation..... Ok fine with the throttle anticepation but my question is how probkem shifted to other engines if the problem was with NTS BRACKET itself... Moeed Hussain Sb GS/JG/FI/FR are familiar with them, how to coordinate FR with FI Regards Munir Abbasi Quote Link to post Share on other sites
Moeed hassan 0 Posted October 18, 2018 Share Posted October 18, 2018 My dear respected munir abbasi.....do u means how to consult FI according to reported defect???? Ok cool. It is pretty difficult to write it here but in short first of all u will find the FAULT CODE of your defect in the CONCERNING SYSTEM FI..... after geting code u will have to fine that code in the same FI and then u will b able to isolate that fault according to FI. I THINK IT WOULD B HELPFUL TO U. REGARDS. Quote Link to post Share on other sites
