zkw Posted December 17, 2019 Share Posted December 17, 2019 I am working on a 130J which is converted to a maintenance trainer. after the ramp was lowered to ADS position i found the manual dial set at #5. the ramp locks are extended with the ramp open. I am unable to retract the locks manually. setting the dial at #1 will raise the ramp but will not disengage the locks. basically i am unable to close the ramp. note: that the Elect/HYD function from the Aux pump has been disabled due to our tear-down process. Any ideas would be appreciated. Note: Fault isolation manuals states to replace the manifold. Quote Link to comment Share on other sites More sharing options...
Metalbasher Posted December 19, 2019 Share Posted December 19, 2019 You might pull the small ramp floor panel that gives you access to the lock actuator. In many cases the structure that secures the actuator ends up being cracked and when actuated just turns in place vs. actuating the locks. Quote Link to comment Share on other sites More sharing options...
A97Stallion Posted December 20, 2019 Share Posted December 20, 2019 the first movement with #1 selected on the manual selector is for the ramp to move up, to unload the locks, until there is a buildup of pressure (500psi i think), then the locks will retrack and you select #2 to pump it down. with the ramp down and locks extended, you can either use the aux pump (which you don't have) and select down, lock will come in, or have some guys standing / pushing on the ramp to provide resistance and the locks will retract with #1 selected. alternatly you can remove the lock actuator panel and manually retrack the locks using the push rods Quote Link to comment Share on other sites More sharing options...
