Hyd pressure
eliasafr
During starting while no2&3 eng running, after switch off hyd pump switch low press worning light goes on but press shows 2200psi on booster press indicator. With no 3eng shutdown press goes zero. Its for C-130B ac. Any suggestion please
Edited by eliasafr
Need a better description of which engines are running, which switches are being energized, and what the other pressure indications display.
For example:
is #4 running or shut down?
what pressure does rudder pressure indicate on panel and in the back near rudder?
Which engines hyd switch are on/off?
Are all engines upsped or downsped
Is the elevator on or off the stop?  Down or pulled up to neutral?
What does the booster accumulator pressure read?
Does the light come on when engines are shutdown?
Please provide more details
