eliasafr Posted November 16, 2011 Share Posted November 16, 2011 what is the way to check the operation of safety valve on ground without pressurizing the aircraft?and in no pressure,aux vent position will it open on ground without pressurizing the aircraft? Quote Link to comment Share on other sites More sharing options...
Steve1300 Posted November 16, 2011 Share Posted November 16, 2011 It is spring loaded closed, so with the aircraft parked and no bleed air pressure on the manifold, it will be closed. However, on military Herks, if you should have bleed air pressure and place the switch in Aux Vent, it will open. You do not have to try to pressurize the aircraft, just the bleed air manifold. Quote Link to comment Share on other sites More sharing options...
tusker Posted November 21, 2011 Share Posted November 21, 2011 There's got to be a procedure for it in the books......or else!!!! Maybe you could apply pressure.........a regulated pressure!!!.......to the valve itself, trying to create the differencial that you need!!. Us at the job on B-737, we apply vacuum outside to do the test!..............All kind of ways I suppose. Quote Link to comment Share on other sites More sharing options...
