sharif101 Posted July 25, 2012 Share Posted July 25, 2012 right front main LDG wheel struck with break assy.we tried to kick & pull by towing tractor but not open.anyone pls help Quote Link to comment Share on other sites More sharing options...
sharif101 Posted July 26, 2012 Author Share Posted July 26, 2012 right front MLG wheel stuck with break assy.we tried to kick off & pull by towing tracktor but failed to open.please anyone give any idea. Quote Link to comment Share on other sites More sharing options...
bischoffm Posted August 6, 2012 Share Posted August 6, 2012 Sometimes if you hit the brake stack using a long brass rod and hammer the stack will free up and allow the wheel to turn. Is that your problem?? Quote Link to comment Share on other sites More sharing options...
Ben Legere Posted August 7, 2012 Share Posted August 7, 2012 A quick and easy way that I have found to remove stuck wheels that are stuck on the brake rotors is to spin the tire counterclockwise as fast as you can then apply the brakes. Usually this will break it loose. If you still have problems. 1 With the ground test valve NOT tied turn the aux pump on 2 Select Normal brakes 3 Set parking brake, you will have no pressure on the brakes at this time 4 spin tire backwards as fast as you can do by hand 5 once tire is up to speed select emergency brakes. When brake switch is flipped to emergency it will set the brakes almost instantaneously jarring loose any stuck rotors. You may have to repeat this a few times Is the tire still able to rotate? Quote Link to comment Share on other sites More sharing options...
