gtc bleed pressure
sharif101
when first start any engine.the on speed time approximately 80 second.when start button press gtc bleed pressure going down 14 psi and slowly up to 25psi.gtc bleed pressure 39psi,leak check time 15s,we changed both thermostat,load control valve,fcu but problem remain.please any suggest.
Was it a sudden snag, started overnight or got it worse over time? Do you start with Atm on or off? Do you always start the no 3 Engine first or do you alternate your starts? We start with our Atm on until about 15-30% and then disconnect the Atm for better bleed, especially in Goma and Bukavu with higher altitudes.
