eliasafr Posted September 18, 2015 Share Posted September 18, 2015 the ldg of c_130b extention time more then 8min...what can be done.... Quote Link to comment Share on other sites More sharing options...
hehe Posted September 18, 2015 Share Posted September 18, 2015 8 minutes???????Does your aircraft have the two speed ldg gearbox? Quote Link to comment Share on other sites More sharing options...
NATOPS1 Posted September 18, 2015 Share Posted September 18, 2015 (edited) One side change the LG motor and or flow regulator Edited September 18, 2015 by NATOPS1 Quote Link to comment Share on other sites More sharing options...
eliasafr Posted October 1, 2015 Author Share Posted October 1, 2015 8 minutes???????Does your aircraft have the two speed ldg gearbox?yes already changed motor and flow regulator.... Quote Link to comment Share on other sites More sharing options...
hehe Posted October 1, 2015 Share Posted October 1, 2015 Give me some details. (What hydraulic source? In-flight or on the ground? What is pressure dropping to? Have you checked the MLG snubber above the forward strut?)Are you sure the high speed side of the gearbox is engaged? Make sure the flow regulators are installed free flow towards the motor (regulated flow away from motor) (up line regulates down side of gear/down line regulates up side of gear) Quote Link to comment Share on other sites More sharing options...
munirabbasi Posted October 6, 2015 Share Posted October 6, 2015 the ldg of c_130b extention time more then 8min...what can be done....Check HI torque system (Circuit ,SW, Valve) Quote Link to comment Share on other sites More sharing options...
NATOPS1 Posted October 6, 2015 Share Posted October 6, 2015 (edited) Is it only one side that takes 8 minutes?There are two flow regulators and one snubber for each side.Make sure the snubber actuator lever working and not out of alignment/adjustment. It should only slow the last few inches of travel.If it is both MLG sides it is a flow problem. Does the Nose work ok? Edited October 6, 2015 by NATOPS1 Quote Link to comment Share on other sites More sharing options...
