casey Posted May 25, 2018 Share Posted May 25, 2018 Military satellite communications (SATCOM) provider iDirect Government (iDirectGov) is set to unveil its tactical removable airborne satellite communications (TRASC) for C-130 military transport aircraft at the 2018 Special Operations Forces Industry Conference. TRASC integrates commercial off-the-shelf (COTS) components into an airborne terminal to provide troops with advanced and modern SATCOM technology. The components are integrated, tested and airworthy-certified. Military satellite communications (SATCOM) provider iDirect Government (iDirectGov) is set to unveil its tactical removable airborne satellite communications (TRASC) for C-130 military transport aircraft at the 2018 Special Operations Forces Industry Conference. TRASC integrates commercial off-the-shelf (COTS) components into an airborne terminal to provide troops with advanced and modern SATCOM technology. The components are integrated, tested and airworthy-certified. The iDirectGov solution features multi-band 18in parabolic Ku / Ka dual-band antenna provided by UltiSat. The antenna features a lightweight robust carbon fibre composite frame and high data rates. TRASC also includes SelectTech’s roll-on roll-off transit case integrated with the iDirectGov 9800 AR Satellite Router, power supply and gateway router, and R4’s C-130 hatch or wing shoulder panel. The R4 solution is based on a US Air Force and Federal Aviation Administration (FAA)-approved design for a multi-purpose hatch system. iDirectGov president John Ratigan said: “iDirectGov is excited to partner with leading companies on TRASC, which provides the airforce with a product that meets all the specified communications requirements for the military’s airborne needs, including TRANSEC and military operating standards. “When the military needs communications technology to perform a particular mission, it becomes a costly and time-consuming endeavour to start from scratch and build a solution. “This partnership enables the Department of Defense to leverage the best COTS technology in the marketplace in order to speed up time to market and reduce development costs, all while meeting mission specifications.” The parabolic antenna is said to be the only dual-band antenna that enables TRASC to support both military and commercial Ka frequencies. To support voice and data for C-130 airborne applications, TRASC works with a number of Ka, Ku, X-band or a combination of these. Being a fully FAA-compliant solution, TRASC is compatible with all variants of the C-130 military aircraft and can work with existing iDirectGov hub-based SATCOM networks. View full article Quote Link to comment Share on other sites More sharing options...
