Rosemount and Non-rosemount Pitot Static System.
Too many to list... obvious difference, 4 tubes in the Rosemount vs only 2 in the non. The systems the tubes attach to are all different.
FYI, ONE VERY IMPORTANT aspect is the performance charts are different for the two systems; if you use the wrong chart for calculating your TOLD data you will have incorrect numbers.
Yes, thanks. How about we focus on performances of each thru some phases of flight (landing, T/O, minimums, etc.) why does it have a slight higher minimum control speeds than the non-rosemount.
From what I remember the difference in location changes the airflow around/through the boundary layer and it is more of a pickup /interpretation difference but if you are so inclined you can go through the performance charts and determine it there is a TAS difference.
