Nc97 Posted April 9, 2010 Share Posted April 9, 2010 Anyone know/find a good part number for the Phenolic Hydraulic Clamp Blocks used in the flap wells at station #28? Thanks. Quote Link to comment Share on other sites More sharing options...
yawdamper Posted April 9, 2010 Share Posted April 9, 2010 LP5 through LP11 with following dash numbers depending on tube sizes they support, and they are made of Maple wood. Quote Link to comment Share on other sites More sharing options...
Nc97 Posted April 9, 2010 Author Share Posted April 9, 2010 Wow, outstanding. You wouldn't happen to have T.O Fig. and Index would ya? Quote Link to comment Share on other sites More sharing options...
keepemflying130 Posted April 10, 2010 Share Posted April 10, 2010 Maple wood blocks are crap. If you have any Eng. support, you can have "suitable subs" mfg'd. Best are milled from alum. with Adel rubber around the radius. Other, better than wood are Phenolic, with or without the rubber. Wood was a staple of the era in that capacity. Those lines, for those of you who deal with them, are not very cooperative in the static installation. They do require dynamic relief with respect to hyd press and wing flex, but that is what design radii are for. I have heard that argument, and I cannot subscribe. Milled or phenolic, both are better. Make per sample, have it blessed, and get on with more important gripes. Quote Link to comment Share on other sites More sharing options...
Plaprad Posted April 10, 2010 Share Posted April 10, 2010 We've always made them out of Phenolic. They work great. Quote Link to comment Share on other sites More sharing options...
bischoffm Posted April 11, 2010 Share Posted April 11, 2010 Here is the drawing. Little tough to read , but most people have been able to manage it Quote Link to comment Share on other sites More sharing options...
Metalbasher Posted April 12, 2010 Share Posted April 12, 2010 Phenolic stock is getting harder to come by, given it's composition and being a known carconigen. In the past we've made clamp blocks out of nylon or teflon...local machine shops have ample supplies of this stock on hand. Quote Link to comment Share on other sites More sharing options...
yawdamper Posted April 12, 2010 Share Posted April 12, 2010 That's what I love about the C-130 community, lots of passion. Just pointing out that the original spec calls for Maple and if that is what was ordered, that is what you would get. Sounds as if the spec should be updated to a modern, available material that will perform and hold up under use, as the Maple clampblocks are still being used on production J's. The operator always has the option to substitute their own replacement, but consideration would be to get mother Lockheed to update the material. Quote Link to comment Share on other sites More sharing options...
Metalbasher Posted April 12, 2010 Share Posted April 12, 2010 I agree whole heartedly, but the problem is that the Govt never plans for updating prints after they start recieving the aircraft. It's has happened with all the weapon systems now...C-5, C-130 and C-141...I know I have addressed several things that should have been updated on the prints and the answer is always the same...no money to do that. Doesn't help that Mother Lockheed wants and arm and a leg to do the task either. Quote Link to comment Share on other sites More sharing options...
