Shola
APU LOAD CONTROL VALVE NOT WORKING AND APU NOT SHUTTING DOWN
GTCP85-180L starts and run well. However,  no bleed air from  the APU. Load control valve replaced with new one but no change. In addition,  APU doesn't shut down normally unless by the pull of fire handle. Any help please?
Aircraft type is C130H.
Hi !
Did you checked the Overspeed Solenoide, Valve?
Did you preformed the continuity checks on both electrical plugs (on Load Valve and Solenoid Valve)?
The Filter Between the Load Valve and the Solenoid Valve is clean and Tightened?
Just some questions and some leads!
Kindest Regards!!
