Badiul Alam
C-130 B prop rpm problem
8Hey! Hercules world. I am facing problem with one of my prop of C-130B eng. While opening power lever, rpm goes upto 103% with Freq 410 Hz in Prop gov cont sw in Normal. Afterward rpm slowly back to 102% with Freq 402Hz. In Mach Gov RPM remain ok. We change the indicator guessing that if Frq is 402%, rpm should be 100.2%. No otgers flux. Any suggestion pl.
not sure why mech is ok, but it sounds like internal leak, maybe dome seals, pitchlock regulator
seals, prop retaining nut seals.
As a 1st step we have changed the gauge. Let see what happened next. Thanks a lot.
Thanks a lot
