Zaaz Posted January 17 Share Posted January 17 Hi there after changing propeller #1 we did reindexing but engine #1 doesn't go to over speed . RPM fixed at 100% with Fuel flow 2400. So the pitch lock can't intervene . As operation effected. _change the synchrophaser. _change the valve housing. _Change the propeller assembly. _ change the engine #1 . _ Continuity and insulation measurements between valve housing and syn . But still the same problem. (Engine #1 doesn't pitch lock) Any solution please. Quote Link to comment Share on other sites More sharing options...
Lkuest Posted January 21 Share Posted January 21 If RPM is staying at 100%, and the pitchlock check is the only check that is failing, the only thing that remains is a wiring issue or the switch is broken. I highly recommend you break out the wiring diagram and start checking for open circuits. 1 Quote Link to comment Share on other sites More sharing options...
Zaaz Posted January 21 Author Share Posted January 21 Thanks. We found corrosion in the pin M in the plug horses coller . We repaired the pin and the problem resolved. 1 Quote Link to comment Share on other sites More sharing options...
