Rony Posted May 4 Share Posted May 4 Hi afternoon Is it normal when I change c-130 B phase selector (A-B-C) load meter sudden drops and regain or It problem Quote Link to comment Share on other sites More sharing options...
NATOPS1 Posted July 25 Share Posted July 25 As you rotate the selector you switch the wire contacts so a momentary drop is not a problem because you are not connected to a phase input until you get to the next phase position. You select not only the phase for your freq indicator but also the phase for your load meter. Quote Link to comment Share on other sites More sharing options...
