Steve1300 Posted November 19, 2012 Share Posted November 19, 2012 Anyone have experience with this company's offering for compressor washes? We are looking for a less costly system for after-wash disposals and such, and I am needing to know is their system works as well as the gas path cleaner and rinse system. It may also be known as R-MC Compressor Wash. Thanks, Steve Quote Link to comment Share on other sites More sharing options...
herky400M Posted November 29, 2012 Share Posted November 29, 2012 Steve, try juniper systems, they can provide you with clean rigs whom can be heated til 70°C (if you do your dishes at home, you use also hot water(or the dishwasher:cool:)) We have good results in .BE, on the test rig we put in the soap mix (zok) leave it for 15 minutes (let the foam/soap mix ) do it's work, once more soap mix for 5'minutes and after wise use 110L water to rinse the compressor! If this don't help, you can still use the hard by using wallnuts, or abrassive cleaning. (caution: this can damage your seal between stator and axle) b Quote Link to comment Share on other sites More sharing options...
