[email protected] Posted May 10, 2014 Share Posted May 10, 2014 We get an "Ice detection level 2 " ACAWS under no icing conditions and the plane goes to Ice protection mode. We isolated the fault to a bad Ice Detector, but unable to determine which one out of the two due to the following reasons- (a) ACAWS appears in flight. ( The ACAWS doesn't say no.1 or no.2 Ice detector. Is there a quick and easy way to isolate the faulty Ice detector? We replaced one of them hoping the problem won't reappear...... Quote Link to comment Share on other sites More sharing options...
Coby Posted June 5, 2014 Share Posted June 5, 2014 I know in the JG's there is a procedure to use some spray that will "freeze" an ice detector. So you can ops check the system on the ground. Hope that helps. Quote Link to comment Share on other sites More sharing options...
