FlyingBoat Posted June 1, 2015 Share Posted June 1, 2015 Hello Gents, My name is Sasha, I'm a Naval Architect, all things considered only density separates us. I stumbled upon this forum while searching for cargo floor details, particularly any lashing points or mating interfaces with cargo pallets. I need to design a cradle to carry a boat in the C-130BZ. The boat's design was constrained by the cargo bay dimensions resulting in a vessel of LxBxH 12m x 2.6m x 2.5m (2.6m high when placed on the cradle). This 'package' is inserted into the fuselage of the aircraft and here lies my problem. I cannot find any useful info on the BZ's floor layout wrt lashing eyes or standard lock-in points if there are such things. Ideally I would like the cradle to interface with existing hardware. What options do I have to secure this 6500kg load down? Any information will be greatly appreciated, Looking forward to your thoughts. Cheers. Quote Link to comment Share on other sites More sharing options...
casey Posted June 1, 2015 Share Posted June 1, 2015 I am sure some of our load master friends will poke holes in this idea but assuming that the aircraft is fitted with dual rails and rollers and that there is a k-loader handy:Why not, connect five pallets, build the cradle on the pallets, roll the whole thing in and lock the pallets into the dual rails?--Casey Quote Link to comment Share on other sites More sharing options...
BRlang Posted June 1, 2015 Share Posted June 1, 2015 I have transported the barrel of a 175 ( 30,000 lbs) on three married pallets but the aircraft starts to settle as the load comes off the ramp. Even with the milk stool it squats bit. I could see the chance of 5 pallets binding but it looks like this thing only weighs 16,000 lbs...If you can get 5 connected you don't have much play in the CG...Make sure the boat has the cg marked and the mid point can fall some where in G or H...Get some of the new guys involved ..If it fits through the door it can be hauled...Another thing to consider is proper restraint.. Make sure it can get 4 Gs minimum forward..8 is better.. Quote Link to comment Share on other sites More sharing options...
FlyingBoat Posted June 2, 2015 Author Share Posted June 2, 2015 Thank you for the suggestions so far guys. I'm looking into the standard pallet option now to figure out a way to attach my cradle. Welding is out as the pallet is AL and the cradle is FE, also the cradle goes with the boat for dry-docking. If anyone has the pallet dimension on hand, please share. Quote Link to comment Share on other sites More sharing options...
BRlang Posted June 2, 2015 Share Posted June 2, 2015 463L pallet is 88"X108". The pallet has tie down points all around it but I am still not sure if you can get 5 chained together. Good luck with it. I was flight crew. Some of the Aerial Port Cargo specialist might have better suggestions. 3 together is the most that I have had experience with.. Quote Link to comment Share on other sites More sharing options...
FlyingBoat Posted June 2, 2015 Author Share Posted June 2, 2015 Many thanks! Quote Link to comment Share on other sites More sharing options...
