Badiul Alam Posted May 26, 2020 Share Posted May 26, 2020 Can anybody explain the probable causes of static oil leakage aftet eng idle grd run from Turbine rear bearing( flooding in front of 4 th stage rotor), burner drain vslve( rear one), 6:O clock, lower bleed valve. Tank oil lvl also reduced from 10.5 to 3.5. But during run Everything was fine. Eng is only 1021:44 hrs op after OH. Quote Link to comment Share on other sites More sharing options...
pjvr99 Posted May 26, 2020 Share Posted May 26, 2020 Main oil pump: pressure regulator poppet valve has cracked Quote Link to comment Share on other sites More sharing options...
Badiul Alam Posted May 26, 2020 Author Share Posted May 26, 2020 3 hours ago, pjvr99 said: Main oil pump: pressure regulator poppet valve has cracked Thanks a lot. Quote Link to comment Share on other sites More sharing options...
Badiul Alam Posted May 26, 2020 Author Share Posted May 26, 2020 3 hours ago, pjvr99 said: Main oil pump: pressure regulator poppet valve has cracked Ok. For this, can oil leakage occur from rear bearing(Exhaust cone/ Dome over the pump) bottom side just front of the 4 th stage turbine rotor viewed from rear. Quote Link to comment Share on other sites More sharing options...
pjvr99 Posted May 27, 2020 Share Posted May 27, 2020 Yes, because it is flooding through the delivery nozzles and tubes as though the engine were running Quote Link to comment Share on other sites More sharing options...
Badiul Alam Posted May 27, 2020 Author Share Posted May 27, 2020 7 hours ago, pjvr99 said: Yes, because it is flooding through the delivery nozzles and tubes as though the engine were running Thanks a lot Quote Link to comment Share on other sites More sharing options...
