ICS control issue in C-130B
Hello brother
In C-130B model, if VHF 1 or 2 is selected from either pilot or copilot side ,, the RT reception is also found from opposite position, that is if VHF 1 is selected from captain side, Copilot can here that call at the same time in a  large volume. Where could be the problem?? Nav side and Flt engr position is ok.. only problem with pilot and copilot side.
Thank you in Advance
Edited by Kamrul Ahsan
  • 3 weeks later...
What ICS system do you have? The following info is for the AIC-14 system...
Change the P and CP AMP selected from Norm to Alt 1 or Alt 2
Also inside the ICS and Radio select boxes there is a jumper to "change the function of the box (same box two functions) make sure the jumper it tight (remove clean contacts and reinsert jumper)
If there is a problem with the ICS the boxes will change to a sort of "Hot Mic" function connecting the P and CP ICS
Edited by NATOPS1
