Guest Posted September 22, 2010 Share Posted September 22, 2010 Just wondering any of you guys experiencing this with PFD/MFD displays (LCD Displays). With VOR 51RV-1, -4, -5, it was found that the VOR bearing will be out of view at exactly 90 and 270 degrees. This is confirm both on ground using test set and in flight. Anyone faces the same problem as well? Quote Link to comment Share on other sites More sharing options...
tinyclark Posted September 22, 2010 Share Posted September 22, 2010 Doest his mean the pointer blanks out/disappears? Does the To/From CDI work on the HSI display? We had a problem on a C9 many many years ago, but the specifics are sketchy. Since the FMS800 system didn't need the OBS lines going from the HSI heading set to the VOR, they wired the OBS lines at the VOR into a resistor network. One of the crimps was bad on a resistor. Not sure how yours is set up, since I have no wiring diagram to look at. Quote Link to comment Share on other sites More sharing options...
Guest Posted September 29, 2010 Share Posted September 29, 2010 Is the resistors for the Reference AC Voltage? Quote Link to comment Share on other sites More sharing options...
tinyclark Posted September 29, 2010 Share Posted September 29, 2010 Quite honestly, I am not sure how that resistor network works. Do you have SCNS on your aircraft? AND, by PFD/MFD, do you mean the electronic ADI and HSI, or do you have large panels? Quote Link to comment Share on other sites More sharing options...
Guest Posted October 1, 2010 Share Posted October 1, 2010 No SCNS and its the large panels from Rockwell Collins. At troubleshooting page of PFD, the signal went to 0 at 90/270 in the status page. Quote Link to comment Share on other sites More sharing options...
tinyclark Posted October 1, 2010 Share Posted October 1, 2010 If it does it on all of your aircraft like this, there may be a video driver problem. Maybe the VOR receiver signal isn't strong enough to drive it correctly. Are the NAV station indicators working correctly? Are they switched to VOR when the MFDs are having the problem? If they are, maybe they are creating too much of a load. I wish I could help you more, but I am still used to this old analog stuff. By the way, what country are you in? Just curious. Quote Link to comment Share on other sites More sharing options...
