Prop low oil light
sharif101
No 4 propeller sometimes comes low oil warning light & automatically goes out.hydraulic level is available.check float switch,wiring is ok.change pump housing but action.please give suggestion.
Check the wire connections at the engine firewall. We had one plane that had an intermittent prop low oil light because of a shorted wire on the QEC quick disconnects.
I've also had one because of the twist in the connector at the prop itself. The "power in" wire found a ground when the insides turned and the wires crossed.
