Ahmer Posted October 29, 2018 Share Posted October 29, 2018 If u propeller feather or unfeather on ground its means u switch is working, u said ur rpm rewind at 60 % rpm .its mean when u restart engine ur prop angle changed( from 92degree towers flight idle) and prop start rotating .go to an other option it's means switch & circut good properly working .u check other option because rpm not sustained ur engine.sometime malfunction of td system at auto .regards Quote Link to comment Share on other sites More sharing options...
Shola Posted October 29, 2018 Author Share Posted October 29, 2018 18 minutes ago, Ahmer said: If u propeller feather or unfeather on ground its means u switch is working, u said ur rpm rewind at 60 % rpm .its mean when u restart engine ur prop angle changed( from 92degree towers flight idle) and prop start rotating .go to an other option it's means switch & circut good properly working .u check other option because rpm not sustained ur engine.sometime malfunction of td system at auto .regards Thank you very much. Quote Link to comment Share on other sites More sharing options...
Shola Posted October 29, 2018 Author Share Posted October 29, 2018 37 minutes ago, Ahmer said: Thanks for the diagram Quote Link to comment Share on other sites More sharing options...
munirabbasi Posted October 30, 2018 Share Posted October 30, 2018 (edited) On 10/29/2018 at 3:30 PM, Ahmer said: Good view of the condition lever.Electronic Control Valve housing has air start switch used when NTS SW is selected to NTS or Valve during air start. Regards Munir Abbasi Home of hercules Pakistan Edited October 30, 2018 by munirabbasi Quote Link to comment Share on other sites More sharing options...
superbigbig Posted June 10, 2020 Share Posted June 10, 2020 控油器故障? Quote Link to comment Share on other sites More sharing options...
