munirabbasi Posted November 13, 2020 Share Posted November 13, 2020 Hello World Power plant expertise of T-56 A-15 Engine parameter cross the limitation TIT 1100 Celsius, Torque 20000 inch pounds fuel flow meter also cross limitation and could not control by throttle movement. Enine was shutdown as per procedure lay down -1 can some body explain what is the reason behind it and can we run the engine to repeat the defect without rectification. Best Regards Munir Abbasi Quote Link to comment Share on other sites More sharing options...
pjvr99 Posted November 13, 2020 Share Posted November 13, 2020 You will need to do a complete overtorque inspection of the QEC kit and truss mounts, and also complete overtemp inspection and borescope the turbine, IGV and combustion liners before attempting to start that engine again Quote Link to comment Share on other sites More sharing options...
munirabbasi Posted November 13, 2020 Author Share Posted November 13, 2020 8 hours ago, pjvr99 said: You will need to do a complete overtorque inspection of the QEC kit and truss mounts, and also complete overtemp inspection and borescope the turbine, IGV and combustion liners before attempting to start that engine again Thanks Peter I need your E mail Address. Best Regards Munir Abbasi Home of Hercules Pakistan Quote Link to comment Share on other sites More sharing options...
