munirabbasi Posted December 19, 2020 Share Posted December 19, 2020 Hello Herks flyer! Any body (PL) know that, from where reference is (TM) made to engine ground start sequence 3421 by aircrew for normal flying departure??? Munir Abbasi Home of Hercules Pakistan Quote Link to comment Share on other sites More sharing options...
hehe Posted December 19, 2020 Share Posted December 19, 2020 It is in the Aircrew's starting engines checklist of the flight manual. It says something like "normal starting sequence is 3 / 4 / 2 / 1" depending on which flight manual you read Quote Link to comment Share on other sites More sharing options...
hehe Posted December 19, 2020 Share Posted December 19, 2020 Here is a C-130 flight manual for reference. This sequence started on A models because the GTC door had to be manually closed and the engine generators were split between inboard/outboard. So they would start #3 and #4 and then shut down GTC, manually close the door and then start left wing. Some pubs mention starting engines in a different sequence than 3/4/2/1 to spread the wear and tear on engine starters. The first engine started off of GTC/APU Bleed air will wear faster than the others with engine bleed air because of the higher flow/pressure from the engines. Generally speaking, if you 100% always start #3 first, data/trends say that you will replace the #3 engine starter before the other engines. 1 Quote Link to comment Share on other sites More sharing options...
munirabbasi Posted December 20, 2020 Author Share Posted December 20, 2020 10 hours ago, hehe said: Here is a C-130 flight manual for reference. This sequence started on A models because the GTC door had to be manually closed and the engine generators were split between inboard/outboard. So they would start #3 and #4 and then shut down GTC, manually close the door and then start left wing. Some pubs mention starting engines in a different sequence than 3/4/2/1 to spread the wear and tear on engine starters. The first engine started off of GTC/APU Bleed air will wear faster than the others with engine bleed air because of the higher flow/pressure from the engines. Generally speaking, if you 100% always start #3 first, data/trends say that you will replace the #3 engine starter before the other engines. Thanks tremendous response Is t SAFAR safety regulation by FAA Or USAF safety regulation ,any safety caution reference of TM or FM is available please mention the text Best Regards Munir Abbasi Home of Hercules Pakistan Quote Link to comment Share on other sites More sharing options...
