Md Abu Sufian Posted September 24, 2021 Share Posted September 24, 2021 The air crew were detailed to carr out a regular cargo msn on route Bunia to goma in C-130B ac ser no 0962.During the takeoff roll,after 60 knots, capt shifted his hand to flt con leaving the nose wh steering as the normal procedure. but at about 80 knots the ac suddenly swung to the left,the capt immediate decided to abort the msn and ac control by applying differential braking with the help of the co-pltand nose wh steering input. Finaly we suspected that nose steering control valve malfunction during ac speed 80 knots. What might be the reason can anyone inform. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
munirabbasi Posted September 24, 2021 Share Posted September 24, 2021 7 minutes ago, Md Abu Sufian said: The air crew were detailed to carr out a regular cargo msn on route Bunia to goma in C-130B ac ser no 0962.During the takeoff roll,after 60 knots, capt shifted his hand to flt con leaving the nose wh steering as the normal procedure. but at about 80 knots the ac suddenly swung to the left,the capt immediate decided to abort the msn and ac control by applying differential braking with the help of the co-pltand nose wh steering input. Finaly we suspected that nose steering control valve malfunction during ac speed 80 knots. What might be the reason can anyone inform. Thanks in advance. Steering control valve lost spring tension It is, mal function of the component, install gauge check pressure on neutral position at point mention on TO (40 psi )as as per TO regards Munir abbasi Quote Link to comment Share on other sites More sharing options...
munirabbasi Posted September 24, 2021 Share Posted September 24, 2021 13 minutes ago, Md Abu Sufian said: The air crew were detailed to carr out a regular cargo msn on route Bunia to goma in C-130B ac ser no 0962.During the takeoff roll,after 60 knots, capt shifted his hand to flt con leaving the nose wh steering as the normal procedure. but at about 80 knots the ac suddenly swung to the left,the capt immediate decided to abort the msn and ac control by applying differential braking with the help of the co-pltand nose wh steering input. Finaly we suspected that nose steering control valve malfunction during ac speed 80 knots. What might be the reason can anyone inform. Thanks in advance. Also check LDG torque strut all Strut are same hard or soft and check for Air pressure if soft all strut pressure should be 415 PSI Munir Abbasi Quote Link to comment Share on other sites More sharing options...
Antonio Posted May 6 Share Posted May 6 Also, propeller malfunction causes that veer. Becare! Quote Link to comment Share on other sites More sharing options...
