Check Team FR Posted November 18, 2024 Share Posted November 18, 2024 After installation of prop assy on the prop shaft, the propeller turn in opposite direction. 1) Magnetics plugs checks on Gearbox but they are perfect, no traces of metal particles. 2) To be sure, we had fushed the gearbox : after this operation, the prop brake works by manual action. 3) On the other hand during the runnup, the prop brake no longer works. 4) The magnetic plugs are still correct. Why did the prop brake work after flushing ? But no longer work after ? What is the cause or problem with the brake ? Thank u in advance for your answer... Quote Link to comment Share on other sites More sharing options...
Lkuest Posted November 18, 2024 Share Posted November 18, 2024 I don't understand what you mean by "during runnup, the prop brake no longer works." The starter disengages the propeller brake at initial RPM, then is held apart by oil pressure as the engine accelerates. If you mean "after engine operates and is shut down," then you may have a defective propeller brake. Of note, it is normal for the propeller brake to not work below certain cold ambient air temperatures due to excess oil viscosity (engine has not been run). As for why it works after brake flush and not after engine run, I don't know. It may have something to do with the manual separation of the prop brake that makes it seat better. You can confirm this by inserting the tool to unseat the prop brake, apply air, then immediately removing it without flushing the gearbox to see if the problem duplicates. Also, if the propeller brake pads are worn, flushing will only help a little. You'll still have worn brake pads. Quote Link to comment Share on other sites More sharing options...
Check Team FR Posted November 19, 2024 Author Share Posted November 19, 2024 Yes, during runnup is normal, the brake release. When the engine shutdown, the brake was inoperated. Quote Link to comment Share on other sites More sharing options...
pjvr99 Posted January 1, 2025 Share Posted January 1, 2025 The only check for defective prop brake is in-flight shutdown. If it rotates, it has failed. On the ground there is no check. The prop can be rotate back- and forwards. Prop brake is released during initial start at about 5%rpm by oil pressure, and stays released until engine stops again Quote Link to comment Share on other sites More sharing options...
