casey Posted February 24, 2008 Share Posted February 24, 2008 Need some help for a 3d model I am working on. What is the diameter of the fuselage? Is it a perfect cyliner? Quote Link to comment Share on other sites More sharing options...
Steve1300 Posted February 25, 2008 Share Posted February 25, 2008 It is actually a circle of about 165.2 inches in diameter. We don\'t actually notice it, especially on a short Herk, because the center wing box and wheel well pods disrupt the appearance.Then, the nose from 245 forward and the tail at 737 change the shape. So, my answer would be that the \"aluminum tube\" we fly around in is, indeed, a circle. :) Quote Link to comment Share on other sites More sharing options...
casey Posted February 25, 2008 Author Share Posted February 25, 2008 Thanks for the info. It was 245 to 737 I was wondering about. I knew it had to be about 13.5 feet but then I saw it listed as 3.22m (just over 10 feet) and I got confused. I believe the difference in the curvature above and below the center line (wl ?) forward of 245 makes 245 -737 look a little squashed. Quote Link to comment Share on other sites More sharing options...
stevoe Posted February 25, 2008 Share Posted February 25, 2008 But Casey, please don\'t forget the breaks where the cargo floor is... Quote Link to comment Share on other sites More sharing options...
Guest Posted February 25, 2008 Share Posted February 25, 2008 As best my memory serves me, there is a little less curvature on the belly, as compared to the sides and top. The points marked on the picture above are where the break occurs. That is just about the location of the cargo floor, and the chine plates that run the length of the cargo compartment. A mechanical drawing would no doubt call out the change in the curvature, but I just don\'t have one handy... Quote Link to comment Share on other sites More sharing options...
stevoe Posted February 26, 2008 Share Posted February 26, 2008 Casey, please take a look at the website of braz models. http://www.brazmodels.com/3D%20CAD/3D%20CAD.htm They have made a 3D model exclusiv for Minicraft, it looks not bad. Another question: Which drawings of the Herk did you use as a base for your 3D model? Best wishes Stephan Quote Link to comment Share on other sites More sharing options...
Guest Posted February 27, 2008 Share Posted February 27, 2008 The \"break\" in the fuselage curvature can be seen in the current Photo of the Week( 2/27/08), the USMC KC-130J. Looking just below the crew entrance door you can see the line going back to the forward end of the APU/Wheelwell housing (the line actually continues underneath the housing), and continuing from the aft end of the housing just below the Paratroop door, ending at F.S. 737, where the cargo ramp attaches. Quote Link to comment Share on other sites More sharing options...
casey Posted February 28, 2008 Author Share Posted February 28, 2008 Thanks for the info guys. Having looked closely I can now see the difference in the curvature. I am not using using a specific drawing, just a mix of drawings and photos. If anyone has any accurate line drawings and would be willing to hook me, I would be most appreciative. Quote Link to comment Share on other sites More sharing options...
stevoe Posted February 28, 2008 Share Posted February 28, 2008 The best drawing I know is from 1978, published in \'Famous Aircraft of the World\' from Koku-Fan. I have scanned this drawing and send it to you by email. I have also made a comparison between this drawing and a small airplane station diagram from a Lockheed handbook, it is a pdf file, scale 1/100. Hope it helps... Quote Link to comment Share on other sites More sharing options...
casey Posted February 29, 2008 Author Share Posted February 29, 2008 Those pics are perfect. Thanks! Quote Link to comment Share on other sites More sharing options...
Shadoif Posted March 2, 2008 Share Posted March 2, 2008 Quote Link to comment Share on other sites More sharing options...
ec130crewchief Posted March 20, 2008 Share Posted March 20, 2008 I\'m going to have to go digging around my reference materials... what has been said about curvature breaks is accurate; and the brake occurs at the floor level. If you need more pictures, or pictures that show the change and chine angle better, drop me a line... Quote Link to comment Share on other sites More sharing options...
Daveian Posted April 25, 2008 Share Posted April 25, 2008 I\'ve been working on a 1/10 scale model of the Herc for a number of years (too many). Besides a number of engineering drawings obtained from MicroFiche at the Smithsonian, I have a very valuable little blue C-130 E/H HANDBOOK. In it are given the following measurements using standard nautical terms. Starting with a waterline of 0, the bottom of the fuselage is at WL126. It\'s crazy I know but if you draw a horizontal line and call it WL, everythings goes up from there. The break on the bottom occurs at WL 141.4, the cargo floor at WL 146, the center line at WL 200 and, top of fuselage is at WL 285. If you use the top 285 minus the center line 200 gives you the radius. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Fergy Posted April 26, 2008 Share Posted April 26, 2008 Hi I hope this helps The herc is measured in three way 1 is the water line but also uses bl (buttock line) and fuselage station FL The BL is actually the width of the a/c from the center of the plane. So starting from the middle of the a/c you go left or right. For example the wheel well bulkheads start on both side are at BL61.25\"L and 61.25\"R so maybe using the BL will give you the diameter of the fuse. I am also pretty sure WL 200 in not the exact center, it is the flight deck floor WL and the top of the wheel wells I would have to look in the book I hope this helps a little Quote Link to comment Share on other sites More sharing options...
Shadow-D Posted January 13, 2009 Share Posted January 13, 2009 (edited) The best drawing I know is from 1978, published in \'Famous Aircraft of the World\' from Koku-Fan. I have scanned this drawing and send it to you by email. I have also made a comparison between this drawing and a small airplane station diagram from a Lockheed handbook, it is a pdf file, scale 1/100. Hope it helps... Sorry for jacking this thread... I know this thread is a little stale but some of the information here is really helping me with my "Herk" project... I bought a set of plans to build a 65" WS RC model that I plan to build first then up the size to 1/10th scale. Only problem with it is the nose is from the first C-130's built i.e. it has a "flat" nose. I would be interested in these drawings you have. Would you mind sending me a copy of these? Do these show the size of the "standard" (non flat) nose? Edited January 13, 2009 by Shadow-D Quote Link to comment Share on other sites More sharing options...
Wombat Posted January 23, 2009 Share Posted January 23, 2009 Casey, I have a set of -3, -23 and -36 if they are of any help for specific drawings or profiles. Wombat Quote Link to comment Share on other sites More sharing options...
damnpoor Posted January 23, 2009 Share Posted January 23, 2009 (edited) I was just looking at the dimensions and measurements in the 00GE and as best I can make out the outer fuselage is 14'-3" wide and 12'-4" tall, so it's not a perfect circle as we already knew. The nose is about 85" long. Edited January 23, 2009 by damnpoor Quote Link to comment Share on other sites More sharing options...
Guest Posted January 23, 2009 Share Posted January 23, 2009 Casey, I have a set of -3, -23 and -36 if they are of any help for specific drawings or profiles. Wombat I appreciate the offer but I think I have most of what I need. Shadow-D may want them. The nose is about 85" long. I think you looked at the wrong Fuselage station: 62.6" long according to the image. Quote Link to comment Share on other sites More sharing options...
damnpoor Posted January 23, 2009 Share Posted January 23, 2009 I appreciate the offer but I think I have most of what I need. Shadow-D may want them. I think you looked at the wrong Fuselage station: 62.6" long according to the image. Yeah, you're right. My bad. Quote Link to comment Share on other sites More sharing options...
Shadow-D Posted January 24, 2009 Share Posted January 24, 2009 Casey, I have a set of -3, -23 and -36 if they are of any help for specific drawings or profiles. Wombat Yea I think that would help a lot... The info posted about the nose also seems to help... Thank you Quote Link to comment Share on other sites More sharing options...
Wombat Posted January 24, 2009 Share Posted January 24, 2009 Let me know what drawings you need and I'll copy them for you. You can contact me at: tassiebob@cox.net Quote Link to comment Share on other sites More sharing options...
Shadow-D Posted January 25, 2009 Share Posted January 25, 2009 Let me know what drawings you need and I'll copy them for you. You can contact me at: tassiebob@cox.net I would be looking for the nose and rear cargo door areas... Quote Link to comment Share on other sites More sharing options...
