TD Valve Brake
BDizzle
Only a dummie if you dont ask... and think you know...
The brake keeps the TD metering valve needle "locked in place" (Same fuel correction).
With the throttle above crossover 65 degrees (66 for real) and with the TD switch in AUTO fuel correction occurs. Placing the TD switch in "LOCKED" ("LOCKS") this corrected fuel bypass.
As the throttle is moved to either increase or decrease power the "LOCKED Correction" remains the same, as the brake is "LOCKED".
If there is a TIT increase above 1077, the brake will release and the metering valve needle will reduce fuel to limit the TIT
It's energized released, correct? So when I'm flying around in auto the brake is energized released, when I go to locked it deenergizes to hold bypass, then is reenergized released in null? And the little motor in there simply isn't strong enough to overcome the brake?
..... the little motor in there simply isn't strong enough to overcome the brake?
That's the operating theory, but every once in a while, the TD brake lock test
passes, but fails TD system check by losing TIT and fuel flow when the switch
is moved from AUTO to LOCKED with the anti icing on. Even though the brake
may indicate LOCKED, the valve may still slip away to the NULL position ......
Yes,
Auto-- Energized released so the motor can position the needle as required.
Locked-- De-energized (spring applied) engaged. Motor cannot move needle.
(Yes, "little motor in there simply isn't strong enough to overcome the brake.")
If TIT gets to 1077 the brake will be energized (released) and the needle will move as required to limit TIT.
Null-- The DC side works (brake energized released) but there is NO ac power for the Amp to drive the motor.
As brothers mentioned with some details.
The solenoid operated brake (TD valve brake) is a part of the TD Valve Unit (the brake is located within the TD motor-generator shaft)
Function:
Used to lock (stop) the movement of the motor shaft which control the Bypass Control Needle Valve (Null orifice) when switch selected to LOCKED.
Operation:
In Null and Auto the brake is energized to release (against spring load) and to let the motor shaft free to take the proper position.
The LOCKED position (which normally selected with throttles above x-over to maintain a specified corrected position) the solenoid operated brake will be de-energized thus bushed mechanically by the spring action to lock the motor shaft ; and will remain locked until signalled (energized) by TD amp if an over temperature occurred (+1077C) or switch repositioned to Auto or Null.
