PauloFerreira 0 Posted February 27, 2019 Share Posted February 27, 2019 HELLO!! I'm having a problem with this type of weather radar! R/T (Receiver / Transmitter) P/N-2070401-0101 are burning all the time when the plane goes in flight. Displays (Pilot and Navigator) in Test Mode and Mapping only shows the three colors on the bottm of the displays, even if we change the Range! Thanks in advance for your help! Best Regards!!! Quote Link to post Share on other sites
GaryRobinson 11 Posted February 27, 2019 Share Posted February 27, 2019 20 minutes ago, PauloFerreira said: HELLO!! I'm having a problem with this type of weather radar! R/T (Receiver / Transmitter) P/N-2070401-0101 are burning all the time when the plane goes in flight. Displays (Pilot and Navigator) in Test Mode and Mapping only shows the three colors on the bottm of the displays, even if we change the Range! Thanks in advance for your help! Best Regards!!! Start by checking the waveguides between the R/T and Antenna. Quote Link to post Share on other sites
PauloFerreira 0 Posted February 27, 2019 Author Share Posted February 27, 2019 Hi Gary! We have already checked the waveguide! the problem is that when the plane is grounded, everything seams to be normal apart the colors (just in the bottom of the display.) when the plane goes in flight R/T burns. Is this a sign of over consumption? Quote Link to post Share on other sites
GaryRobinson 11 Posted February 28, 2019 Share Posted February 28, 2019 I'm not sure Paulo. All my career was on APN-59 on C-130's and Multi-mode on C-5 with a couple of years on MH-53 with APQ-158 Terrain-Following. Never worked on color weather radar. Need to get an answer from someone else on the color weather radar. Quote Link to post Share on other sites
tinyclark 34 Posted March 3, 2019 Share Posted March 3, 2019 I am not sure what you mean by burning. Are they actually overheating and smell burnt when the aircraft lands? Or do they just shut down and not come back on when the aircraft is sitting on the ground? Have you tried changing the antenna anyway, or swapping it with another antenna from a different aircraft? Quote Link to post Share on other sites
PauloFerreira 0 Posted March 18, 2019 Author Share Posted March 18, 2019 On 3/3/2019 at 3:01 AM, tinyclark said: I am not sure what you mean by burning. Are they actually overheating and smell burnt when the aircraft lands? Or do they just shut down and not come back on when the aircraft is sitting on the ground? Have you tried changing the antenna anyway, or swapping it with another antenna from a different aircraft? Hi Tiny, When we pass from warm up to Map the R/T just shuts down because it seams to burn the power supply. we have changed the antenna, swapped with onother palne, it's the same!! The other problem is : when we are able to put the system running (because it works some times) we have only three little dots in the center bottom of the dysplay. Quote Link to post Share on other sites
tinyclark 34 Posted April 8, 2019 Share Posted April 8, 2019 Paulo, I wish I could be more help. I don't have any wiring diagrams to look at, especially for the video problem. Does the R/T sit in the aircraft cabin. Is the antenna a dish or flat array? I think this is similar to the RADAR we had on the C-141. Quote Link to post Share on other sites
