Farhanz Posted June 28 Share Posted June 28 (edited) Hye guys. Looks like im having some trouble regard my fuel gov and pitch lock cx. The propeller was not overshoot to 103.5% or even more when fuel gov switch been actuated. From that, for sure propeller will not pitch lock. Engine parameters during take off power and fuel gov switch actuated was as below : TQ : 17K RPM : 99.6% TIT : 1078 FF : 2.2 Rectification been carried out as below: 1. FCU worm shaft adjusted (increase almost 6 turns) 2. Synchrophaser replacement 3. Pitch lock regulator and packing replaced. 4. FCU replaced. yet, all those thing been carried out. However, the RPM still not overspeeding during actuating fuel gov switch upon fuel gov and pitch lock cx. Please help me my fellows Edited June 28 by Farhanz Quote Link to comment Share on other sites More sharing options...
Lkuest Posted June 30 Share Posted June 30 If you are at power, actuate the switches, and the RPM does not increase at all and fuel flow does not decrease at all, the problem is in the synchrophasing system. This includes the switches, wiring, and valve housing electrical components. Without the electrical components being good, neither the pitchlock regulator nor the fuel control can cause the issue because they're not given the opportunity to do anything. This also assumes the low pitch stop is adjusted correctly. Quote Link to comment Share on other sites More sharing options...
pjvr99 Posted July 7 Share Posted July 7 if there is no RPM increase at all, the signal from the Fuel governing switch is not getting to the valve housing. That is where you need to start looking ..... Quote Link to comment Share on other sites More sharing options...
