mooseherc Posted December 18, 2010 Share Posted December 18, 2010 I am assuming it's the same as other models. What is the max width a piece of rolling stock can be? With and without the dual rails installed. Also the max width before the wheel well. Thanks. Quote Link to comment Share on other sites More sharing options...
P3_Super_Bee Posted December 18, 2010 Share Posted December 18, 2010 I am assuming it's the same as other models. What is the max width a piece of rolling stock can be? With and without the dual rails installed. Also the max width before the wheel well. Thanks. Dual Rails??? Are you referring to the flip-up rails that run down the center of the cargo hold? On a "J" there is nothing to "install". But fuselage dimensions are same as legacy aircraft. Quote Link to comment Share on other sites More sharing options...
mooseherc Posted December 19, 2010 Author Share Posted December 19, 2010 The rails that hold pallets in. I know maint can remove them on the pre-J models. Quote Link to comment Share on other sites More sharing options...
loadsmith Posted December 20, 2010 Share Posted December 20, 2010 do you guys have a vehicle you are trying to load or are you just looking for the dimensions of the cargo compartment? The J-30 is the same width as the E/H, just longer (sts) Quote Link to comment Share on other sites More sharing options...
Whiskeyglenn Posted December 27, 2010 Share Posted December 27, 2010 If my memory serves me correctly, the dual rails are 108 inches apart, that is for the wheels. Above that I think the limitation is 123 inches for the cargo compartment. Rg Glenn Quote Link to comment Share on other sites More sharing options...
Herkloadie Posted January 8, 2011 Share Posted January 8, 2011 Can't be 108...pallets are 108" wide and the dual rails cover part of the pallet flanges. Maybe 104"-106"? Edit: Can't find it in my -9 (C-130A)...cargo compartment general width is 10'3" but it doesn't say how much the dual rails cover. Late models have 35" treadways with a 30" gap between them though...so 105" ish? Quote Link to comment Share on other sites More sharing options...
