sharif101 Posted February 19, 2013 Share Posted February 19, 2013 what is the limitation of voltage flactuation of engine driven AC GENERATOR of c-130b aircraft. Quote Link to comment Share on other sites More sharing options...
gmac Posted February 20, 2013 Share Posted February 20, 2013 Stabilized output should be within 112-118 V. Westinghouse voltage regulators are adjustable, GE units are not. Quote Link to comment Share on other sites More sharing options...
Ronc Posted February 20, 2013 Share Posted February 20, 2013 what is the limitation of voltage flactuation of engine driven AC GENERATOR of c-130b aircraft. Sharif, I have never heard of any limit associated with fluxing voltage, I can't even begin to imagine the damage that would do to the equipment on that AC bus. Ron Quote Link to comment Share on other sites More sharing options...
BDizzle Posted February 20, 2013 Share Posted February 20, 2013 Sharif, I have never heard of any limit associated with fluxing voltage, I can't even begin to imagine the damage that would do to the equipment on that AC bus. Ron Do B models have a GCP? Quote Link to comment Share on other sites More sharing options...
NATOPS1 Posted February 23, 2013 Share Posted February 23, 2013 what is the limitation of voltage flactuation of engine driven AC GENERATOR of c-130b aircraft. Your Generator is constant speed (unless your RPM is moving) so Voltage should be steady however voltage is "always" going up and down and your VR adjust the excitation to increase or decrease voltage. Your range is 110-125 but steady volts are the norm. Swap your VR with another and see if it follows may be as simple as a week VR. Do B models have a GCP? Yes at least our version of the B model (F)... Quote Link to comment Share on other sites More sharing options...
gmac Posted February 23, 2013 Share Posted February 23, 2013 See 1C-130B-2-7 pgh. 3-103 for operational check, pgh. 3-137 for Westinghouse voltage regulator adjustment. 115V + or - 3 is range. Quote Link to comment Share on other sites More sharing options...
sharif101 Posted February 23, 2013 Author Share Posted February 23, 2013 thanks to all for nice idea. Quote Link to comment Share on other sites More sharing options...
