Allison 501-D22A Engine
Ahmer
2 things will happen here:
1- you will lose the commercial (civilian) certification for the D22
2- you will have no fuel flow indication.
The T56 engine uses a 28v DC power supply for the ff transmitter and indicators, while
the D22 uses a 115v 400hz power supply. The wiring and connectors are completely
different.
In my opinion this would be a completely wasted excercise, not to mention the expense
of recertifying the D22 again
  • Like 1
different.
Ok tnx pjvr99
On 11/8/2018 at 10:16 PM, Ahmer said:
Can we use Allison 501-D22A commercial engine on military aircraft in place of T56-A-15 engine officially or by permission of civil aviation authority/ FAA.
See Lockheed martin Service magazine news T56-A-15 Engine 501-D22A  Engine
Regards
Munir Abbasi
Edited by munirabbasi
10 hours ago, munirabbasi said:
Mr munir in service news not mentioned about the use 501-D22A on military aircraft and differance between both engine spacification .plz send me service news no which mentioned about these things. Regards
Edited by Ahmer
  • 2 months later...
Go to AerexAvionics.com to learn about the Fuel Flow Interface used on the C-130 and other platforms for many years to access the fuel data from the fuel flow transmitter to the FMS. The Interface converts the 2nd Harmonic to DC or AC Linear for the FMS to receive the fuel data. Copy of the STC included in the install manual with a one time use agreement. DERCO is a distributor of the unit or MROs can contact Aerex directly. Hope this helps with your modification research.
