Wheto Joseph Seyon Posted April 14, 2021 Share Posted April 14, 2021 This particular sbag has been disturbing the team for the oast few weeks. What could be the cause, we have replaced the control unit, antenna and also TR unit. Checked every component in the system for serviceability but it still persists. Quote Link to comment Share on other sites More sharing options...
munirabbasi Posted April 17, 2021 Share Posted April 17, 2021 On 4/14/2021 at 5:09 AM, Wheto Joseph Seyon said: This particular sbag has been disturbing the team for the oast few weeks. What could be the cause, we have replaced the control unit, antenna and also TR unit. Checked every component in the system for serviceability but it still persists. kindly mention RADAR is installed on your birds . Best Regard Munir Abbasi Quote Link to comment Share on other sites More sharing options...
Danoo Posted April 17, 2021 Share Posted April 17, 2021 Make & Model of your Radar? In such case leveling of the Radar pedestal is also to be verified. Regards Quote Link to comment Share on other sites More sharing options...
tinyclark Posted April 18, 2021 Share Posted April 18, 2021 Is the antenna following the tilt knob? What system is it? Quote Link to comment Share on other sites More sharing options...
NATOPS1 Posted April 18, 2021 Share Posted April 18, 2021 On 4/13/2021 at 7:09 PM, Wheto Joseph Seyon said: This particular sbag has been disturbing the team for the oast few weeks. What could be the cause, we have replaced the control unit, antenna and also TR unit. Checked every component in the system for serviceability but it still persists. NOT a lot of info tto work with but IF the ground returns are only on one side of the display your ANT gyro stabilization is probably bad 1 Quote Link to comment Share on other sites More sharing options...
Wheto Joseph Seyon Posted April 20, 2021 Author Share Posted April 20, 2021 On 4/17/2021 at 2:08 AM, munirabbasi said: kindly mention RADAR is installed on your birds . Best Regard Munir Abbasi Bendix color weather radar RDR-1FBM Quote Link to comment Share on other sites More sharing options...
Wheto Joseph Seyon Posted April 20, 2021 Author Share Posted April 20, 2021 On 4/18/2021 at 5:25 PM, tinyclark said: Is the antenna following the tilt knob? What system is it? Bendix color weather radar RDR-1FBM Quote Link to comment Share on other sites More sharing options...
Wheto Joseph Seyon Posted April 20, 2021 Author Share Posted April 20, 2021 On 4/17/2021 at 3:22 PM, Danoo said: Make & Model of your Radar? In such case leveling of the Radar pedestal is also to be verified. Regards Bendix color weather radar RDR-1FBM Quote Link to comment Share on other sites More sharing options...
Wheto Joseph Seyon Posted April 20, 2021 Author Share Posted April 20, 2021 On 4/19/2021 at 12:11 AM, NATOPS1 said: NOT a lot of info tto work with but IF the ground returns are only on one side of the display your ANT gyro stabilization is probably bad What info do u need? Ask so i can provide them as required. The Radar system is a Bendix color weather radar RDR-1FBM Quote Link to comment Share on other sites More sharing options...
Danoo Posted April 20, 2021 Share Posted April 20, 2021 Few more questions: 1. Does it really paint ground or there may be some permanent targets upto some permanent elevation? In this case your radom may have some moisture accumulated inside which needs to be replaced. 2. External system providing stabilization data to the radar also needs to be verified. 3. You may place some sort of spacers (washers) under lower bolts of the antenna pedestal to elevate radar beam but aircraft leveling also to be ensured before this shortcut. Quote Link to comment Share on other sites More sharing options...
Wheto Joseph Seyon Posted April 21, 2021 Author Share Posted April 21, 2021 On 4/18/2021 at 5:25 PM, tinyclark said: Is the antenna following the tilt knob? What system is it? The model is a Bendix color weather radar RDR-1FBM On 4/18/2021 at 5:25 PM, tinyclark said: Yes. It's following the Tilt Knob. Quote Link to comment Share on other sites More sharing options...
tinyclark Posted July 22, 2021 Share Posted July 22, 2021 Is there a two way bubble level indicator on the antenna? Our APS-133 had one. Insure that the antenna is level on the ground with stab on and off. Quote Link to comment Share on other sites More sharing options...
