Kaydee Posted April 20, 2021 Share Posted April 20, 2021 I am currently facing a challenge where my APU generator OUT light comes ON, but the frequency and voltage is with allowable limit, also, there is load indication. We have changed the contactor, Voltage regulator and the even the APU regulator but the discrepancy persist. Pls I will appreciate any quick response . Thanks Quote Link to comment Share on other sites More sharing options...
munirabbasi Posted April 21, 2021 Share Posted April 21, 2021 On 4/20/2021 at 10:08 PM, Kaydee said: I am currently facing a challenge where my APU generator OUT light comes ON, but the frequency and voltage is with allowable limit, also, there is load indication. We have changed the contactor, Voltage regulator and the even the APU regulator but the discrepancy persist. Pls I will appreciate any quick response . Thanks Kindly check the wiring of auxiliary switching contact of the K-53E and GCP (PIR). Munir Abbasi Quote Link to comment Share on other sites More sharing options...
NATOPS1 Posted April 25, 2021 Share Posted April 25, 2021 Sounds like a bad GCP: internal (PIR) or internal TR... Make sure your GCP is the same manufacture as your generator; ALSO make sure the GCP is fully seated in the rack and might want to "adjust it" with a quick hit/rap/ wack to get all the connections to make good contact. SWAP with one of your Eng Gen CGPs to be sure. Quote Link to comment Share on other sites More sharing options...
munirabbasi Posted April 25, 2021 Share Posted April 25, 2021 2 hours ago, NATOPS1 said: Sounds like a bad GCP: internal (PIR) or internal TR... Make sure your GCP is the same manufacture as your generator; ALSO make sure the GCP is fully seated in the rack and might want to "adjust it" with a quick hit/rap/ wack to get all the connections to make good contact. SWAP with one of your Eng Gen CGPs to be sure. Sir When the load of generator was observed satisfactory in every operation checkout of the system it is malfunction of GCP (PIR) wiring. Best Regards Munir Abbasi Quote Link to comment Share on other sites More sharing options...
Solution Kaydee Posted April 25, 2021 Author Solution Share Posted April 25, 2021 We found a broken cable at one of the terminals of the GCP, wire was spliced and connected back. System tested and found okay. Grateful all for your kind response Quote Link to comment Share on other sites More sharing options...
