Plaprad Posted September 12, 2009 Share Posted September 12, 2009 "the engeineer saw the door open light and straped in to check it out." "I was told was the FE went to check a door wrning light and when he got to the door it dropped off." So what I'm getting from this thread is that FE's should by no means be allowed ANYWHERE near the Crew door during flight. Quote Link to comment Share on other sites More sharing options...
Fleagle Posted September 12, 2009 Share Posted September 12, 2009 I take it the door didn't strike #2 or along the side when it departed? Imagine having to use the Crew Entrance Door for bailout - as I recall it was the last resort if needing to bail out and the -1 EP's stated to push out and downward if using that door........gads! Quote Link to comment Share on other sites More sharing options...
Dave in WV Posted September 12, 2009 Share Posted September 12, 2009 Plaprad, that's why there's a harness secured at the lower bunk for just such an occasion on USAF, USAFR, & ANG C-130's. On preflight the engineer is supposed (required) to check the harness for proper adjustment (fit) and length (keeps you in the plane). Our chief engineer got mad as hell at me because I would tie a loose knot in the tether so I could tell if the length had been messed with because some folks may not know what something is for but will mess with it anyway. To check a door you first depressurize the cabin and go aux vent on the AC control so the door won't blow open. Quote Link to comment Share on other sites More sharing options...
n1dp Posted September 12, 2009 Share Posted September 12, 2009 As the training went at Little Rock, the procedure was to jettison the door, then throw out the NAV so, as he passed under the belly of the aircraft and popped out somewhere near the SPR panel, he would clear all the antennas off! Quote Link to comment Share on other sites More sharing options...
Dave in WV Posted September 13, 2009 Share Posted September 13, 2009 Good plan. We hit a fout point buck on a touch and go (full stopped) and it didn't break off the VHF antenna. He bent it back but didn't break it off all the way. Quote Link to comment Share on other sites More sharing options...
Kwrong1 Posted September 15, 2009 Share Posted September 15, 2009 By looking at the pics of the torque tube i wish i could remember off hand which was which for normal and jettison for the stop bolts. I think its in the jettison position and if so it is possible that if door was improperly rigged the pins will stay in even under a jettison position as it is a close tolerance attach point. Quote Link to comment Share on other sites More sharing options...
Plaprad Posted September 15, 2009 Share Posted September 15, 2009 Everything looks to be closed, I'm guessing either the hooks were too far out and it slipped or they didn't go over-center and it pulled out. The handles and torque tube looks to be in the closed position. Quote Link to comment Share on other sites More sharing options...
kvn_roberts Posted October 20, 2019 Share Posted October 20, 2019 On 5/7/2009 at 4:25 AM, victorp1 said: I have seen two photos and heard a lot of scuttle butt. No "official" information as of yet. Vic Anyone know where I can find a copy of these pictures? Not showing in the forum and have been unable to locate them through a google search. Email possibly if anyone still has them? Quote Link to comment Share on other sites More sharing options...
Spectre623 Posted February 6, 2020 Share Posted February 6, 2020 Hope he was holding on Quote Link to comment Share on other sites More sharing options...
Robert Brown Posted May 23, 2020 Share Posted May 23, 2020 On 9/12/2009 at 8:38 AM, Fleagle said: I take it the door didn't strike #2 or along the side when it departed? Imagine having to use the Crew Entrance Door for bailout - as I recall it was the last resort if needing to bail out and the -1 EP's stated to push out and downward if using that door........gads! I was told that a test was run, throwing a dummy out of the crew entry door, because they were afraid that if you ever used it in flight, you might hit the LH MLG pod. They were surprised when the dummy hit the RH MLG pod because the air swirls around the fuselage. Quote Link to comment Share on other sites More sharing options...
