herkfixer
C-130J with gear problems
Heard about this yesterday on the news and a mil-air monitoring group.
This is a 146th bird from Channel Islands at Peterson AFB, CO.
Word that I had heard was "torque strut had broken" by looking at the picture I would say that the main strut broke and is hanging from the torque strut. In my 21 years crewing I have never heard or seen such a thing.
http://www.gazette.com/articles/landing-116395-springs-airport.html
Click on the "enlarge" for a better view.
73, Rex
I seem to remember hearing a simlar story about a herk where the inner strut separated from the outer strut and the wheel hung free. Definitely not a good situation.
I might have the date in my notes somewhere, but there was a similar incident in '91 or '92 involving a Little Rock bird. As I recall, it was involved in a hard landing at the All-American Drop zone (Camp Robinson?). As the airplane rotated off, the right aft strut came apart. The airplane landed back at LR, and the wheel folded under the fuselage. You could stand in the cargo compartment and see the ground thru the hole it created.
Had a similar incident happen to a Pittsburgh H model '86-0419' at Roosevelt Roads. If I remember correctly, the front right main strut came apart hanging by the torque strut from the aft gear. Gear collapsed when they landed and threw parts of number 4 prop through the fuselage. Nobody hurt but lots of damage.
As you can see in the picture the #4 engine is already "caged" for landing, obviously to avert the problems that you mentioned.
73, Rex
:eek: I literally just walked off that bird for a night profile HE/CDS. Has Pope/Bragg on the tail now but apparently it now "belongs" to the rock for good.
Rec ride-complete :D
TOO MANY PROP BLADES PERHAPS???????????????????????????? Sure would not want to try to tie THAT gear up. Might be a little hard gettin' the chain around it... guess that is still part of the emergency procedure for main gear problems????
Giz
The story said they were out flying around so they must have got the gear up and locked at least once. Wonder what happened to make it suddenly fall apart.
Have to give the crew credit, they thought ahead and shut #4 down. Good job Loadengineermaster
Dunno about the J -1 but the H -1 does mention giving "consideration" to shutting down the OB engine on one side.
A similar malfunction occurred on a Combat Talon 64-0561 after 36 touch and go landings at CCK on 24 November 1966, and the aircraft was flown to a foamed runway at Kadena where it landed safely (from "The Praetorian Starship" by Jerry Thigpen)
I remember that incident. Pretty cool landing.
Engine Mike
Sorry BDizzle
I'll have to decline naming sources.
It is interesting that the gear is up and the problem pieces are dangling.
Senior
